golf 7.5 pla 3.0 hatası
rcpsari67
4 Şub 2019
Recep
aracım golf 7.5 midline plus 2018 model aracıma pla 3.0 montajını yaptım kodlamalarını da yaptım fakat hata alıyorum hizmet dışı vs kodlamada bir yerde yanlışlıklar yaptım heralde çözümü nedir
auto-scan yaptıgımda bu hataları aldım.
Sunday,07,February,2021,17:23:19:00008
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 19.6.0.5
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWZZZAUZJP137120   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CHZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 BH    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H26 5152
   Revision: W1H26---
   Coding: 01250032230411082000
   Shop #: WSC 00028 028 00030
   ASAM Dataset: EV_ECM10TFS01104C906026BH 002004
   ROD: EV_ECM10TFS01104C906026BH.rod
   VCID: 68DF0EA09373D30F3E-803C
No fault code found.
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 042 D    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501803306222
   Coding: 0014
   Shop #: WSC 00028 028 00024
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 377D9DDC8E4D8CF767-8062
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CT    HW: 5Q0 614 517 AG
   Component: ESC           H62 0653
   Revision: 00000000    Serial number: 61058000000852
   Coding: 01FA6AA1142321734778060260C32580562884E26006A4730022F078C202430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 0501271484212E67A5-8050
Address 08: Auto HVAC (J301)       Labels:| 5G0-907-426.clb
   Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
   Component: AC Manuell    H03 1801
   Revision: 00001K06
   Coding: 00020003200110001000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004134
   ROD: EV_ACManueBHBVW37X_004.rod
   VCID: 7AFB44E8FDDF519FD8-802E
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CM    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H36 0253
   Serial number: 01001810101351
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 018001
   ROD: EV_BCMBOSCH_018.rod
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417618093
   Coding: 0271165941
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50AFC6400BE33BCF46-8004
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
   Component: AirbagVW21    006 0336
   Serial number: 003VVR4P5N2M
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002158
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 071D2D1CBE2D3C77D7-8052
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0140
   Revision: --------    Serial number: 10041808490465
   Coding: 0410
   ASAM Dataset: EV_SMLSKLOMQB 020002
   ROD: EV_SMLSKLOMQB_020_VW37.rod
   VCID: 020B3C08950F195F80-8056
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 5G1 920 740 C    HW: 5G1 920 740 C
   Component: KOMBI         202 0310
   Coding: 07A52A082380000801083A001400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009060
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 2643409859E7057FCC-8072
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 K    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5323
   Serial number: 31031811600028
   Coding: 030100047F085700FA0000481C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF.rod
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Component: TSG FS        011 0032
   Serial number: 0000314042845
   Coding: 003003208000020000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 4581E714C4A1EE67E5-8010
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 031F0000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73E569CCDAB520D79B-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Component: TSG BFS       011 0032
   Serial number: 0000312153943
   Coding: 003001208000020000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 4487FA10CF9BD76FF2-8010
Address 5F: Information Electr.
Cannot be reached
End-------------------------(Elapsed Time: 02:57)--------------------------
Hocam bu sekilde yardimci olmak zor. Biraz daha detaylandirabilirseniz yardim edebilecek birileri cikabilir. Kablaj isleminin tam dogru oldugundan eminsiniz degil mi?
@ZaGani gateway baglantısı low olan 8. pin high olan 18. pine baglandı. tuş takımında gri kablo gri olana eklendi
park sensörleri çalıştı fakat park asistanı hizmet dışı hatası veriyor @ZaGani
Abs de hata var. Sanırım abs kodlaması yanlış. 3.0 lerde manevra frenleme de kodlanması gerek.
Parametre hatası muhtemelen. Kendiniz mi yaptınız yoksa dışarıda mı yaptırdınız. Para veripte çalışmayan şey almamışsınızdır umarım.
@Ömer Kahraman Abs'nin kodlanmadığı kesin :)
@rcpsari67 ABS'de Byte 24 değeri 00 yerine 20 Yapıp denermisiniz. Başka yerlerde de vardır ama ABS'de bu eksik en azından.
01FA6AA1142321734778060260C32580562884E26006A4732022F078C202430B00000012121212B835351919323200
Ama malfuntion deyip hiçbir hatada basmamış, @İlker34hocamın dediğide olabilir :)
@Ömer Kahraman
gatewayi high yapacagim yapinca bağlantısı degisiyormu ?
@Ömer Kahraman sorun çözüldü ABS kısmındaki hatayı duzeltince pla çalıştı fakat şuan tek sorun pla ile gelen tuş takımında set tuşunu nasıl aktif edebilirim
[mention=4484]Ömer Kahraman[/mention] sorun çözüldü ABS kısmındaki hatayı duzeltince pla çalıştı fakat şuan tek sorun pla ile gelen tuş takımında set tuşunu nasıl aktif edebilirim
Set tuşu için 2 kablo çekilmesi gerek
Set tuşunun bulunduğu kablo demetinden
Pin 9 dan abs beynine pin 41e tek kablo gidecek.
Pin10 dan sigorta tablosu sc34 e bir kablo gidecek. Böyle çalışır. Çok gerekli değil açıkçası. Mediadan da set tuşu var. Uğraşmaya değmez bence.
