Retrofit'ler sonrasi Kalan Hata
CemK
21 Tem 2019
Istanbul
Cem
Yaptığım eklemelerden sonra araçta baya hata vardi. Çoğu ialwmler sırasında olusanlardi sildim onlari, iki tane kalmisti. Ikiside "Control Module Incorrectly Coded" şeklindeydi. Abs'dekini ACC de olmasini gerektigini dusundugum eksik bi kodlamayi yapinca duzeldi. Ama DashBoard'daki hatanin kaynagini bulamiyorum, yardimci olabilecek var mi acaba?
Araca eklenenler, ACC, On Arka Park Sensorleri (Frenlemeli), Yagmur Far sensörü ve Kararan Ayna, Katlanir Ayna, Kapi alti aydinlatmalar, Arka Ayak Aydinlatma.
Aracin AutoScan:
Friday,24,January,2020,20:32:19:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWZZZAUZFW189030   License Plate: 34KL2921
Mileage: 70649km-43899mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFW189030   Mileage: 70649km-43899miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CXSA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 DF    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H10 7775
   Revision: WAH10---
   Coding: 01250012236401082000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM14TFS01104E906016DF 002006
   ROD: EV_ECM14TFS01104E906016DF.rod
   VCID: 69D908A38879EB0710-803C
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 047 D    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5201
   Revision: 00043014    Serial number: CU501411095887
   Coding: 0014
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 3C7781F7B76BAEAFBB-8068
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63204000000328
   Coding: 01FA6AA1242811750777060341C32980562488E0608294F338225068C202
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 3D718CF3AC71A7A78C-8068
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
   Component: Climatronic   H03 1001
   Revision: 00001K08
   Coding: 00020004200100001005004012101400
   ASAM Dataset: EV_ACClimaBHBVW37X 003018
   ROD: EV_ACClimaBHBVW37X_003_VW37.rod
   Fresh Air Blower Front:
   Geber für Kältemitteldruck/Kältemitteltemperatur:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0137
   Serial number: 01011432302275
   Coding: 00001842C24102FB4BE44000000403081000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 013000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DF14CF3ECF167A7CC-8028
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    141106  043 0551
   Serial number:         141115025830
   Coding: 0E4DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 81A 955 547 A    HW: 81A 955 547
   Component: G397_RLFS  H06 0002
   Serial number: 21741765X81A955547A0
   Coding: 06006C
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418918270
   Coding: 0471051011
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 4C97D137E7CB1E2F0B-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 L    HW: 5Q0 907 567 L
   Component: ACC3          H10 0098
   Serial number: 26081576110689
   Coding: 001E1100FE030B
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 4487F917CF9BD66FC3-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    014 0385
   Serial number: 003F6R0DT21A
   Coding: 98CCC000000000005C0000CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4189F003D089C347E8-8014
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 480 001 411 14
   Component: SideSensor_Df  001 0887
   Serial number: 35767000000C7B80811X
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 911 14
   Component: SideSensor_Pf  001 0887
   Serial number: 3586700000094019B11M
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 480 401 211 14
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502AF188FC05323I
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 480 401 211 14
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502B5188FC13F02I
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 211 14
   Component: FrontSensor_D  001 6149
   Serial number: 3556502B7188FC04416H
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0175
   Revision: FF032032    Serial number: 20141121500516
   Coding: 0410
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3F8DF6FBA67DB5B79E-806A
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 740     HW: 5G1 920 740
   Component: KOMBI         204 4270
   Coding: 078419082780000800883A011400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009037
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 63C51A8B6A55B157DA-8036
1 Fault Found:
13636608 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 63
                    Mileage: 70649 km
                    Date: 2020.01.24
                    Time: 19:06:30
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 03071920000556
   Coding: 030100042F085700CF0002581C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewConti 013020
   ROD: EV_GatewConti_013.rod
   VCID: 7CF741F7F7EB6EAFFB-8028
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001634950035404
   Coding: 300000
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Component: J367-BDMHella  H04 8050
   Serial number: 2479294703
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Component: TSG FS        020 0028
   Serial number: 141114BKD08051
   Coding: 003F0320D000040000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 428BFF0FD58FD85FF1-8016
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000004500634
   Coding: 110000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 R    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB_012_VW37.rod
   VCID: 4385FA0BCA95D157FA-8016
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0028
   Serial number: 161114BKF14631
   Coding: 003F0120DC00040000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000004524797
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 5G0 035 869 B    HW: 5G0 035 869 B
   Component: MU-E--ER      050 7080
   Serial number: 11101600011278
   Coding: 02730000FF00000041110001000100001F0004040000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_VW37.rod
   VCID: 2D51BCB37C1137273C-8078
End-------------------------(Elapsed Time: 03:53)-------------------------
@forjust1day  :)
Eski Kod
Coding: 078419082380000800083A001400000000000000
Yeni kod
3 Değişiklik var ve 3'ü de ACC için olması gerekenler ?
ESP'deki hata ACC'de bi kod değiştirince kalktı mesela, hata modülün kendisi değilde haberleştiği farklı bi modüldeki hatalı/beğenmediği kodlamadan da kaynaklanabiliyor sanırım.
Odis ile bakılırsa düzelir. Vag com tüm kanalları göstermiyor maalesef.
Uyarı ışığı yanıyor mu gösterge de ? Yanmıyorsa sorun yok hocam . Keyfini çıkartın acc nin .
Uyarı yok çalışıyor herşey, ama hataya taktım kafayı temizliycem illa :)
Diğer hata'da varken uyarı yoktu ve herşey çalışıyordu ama benim düşüncem major olmasa da illa arkada bişeyler olduğu yönünde :)
